Every Update I Have To Replace The Task Bar Icon For Thunderbird.
This app comes with lots and lots of updates, and every time I have to delete the old start icon on the task bar and re-pin it. Please, fix it so that I never have to do that again. There is no other software at all including Mozilla Firefox that does this to me.
As I have never needed to do that, despite using ESR, Dail and Beta versions of the software so daily updates are a frequent reality you will need to expand on your statement significantly. Why would you be deleting the icon and repining it?
So every time there is an update and I want to start it up, clicking the icon windows will say that "this item has been deleted or moved, would you like to remove it?" It will also turn into a generic file icon. I have to delete it, then re pin the icon from the start menu.
Jụọ ajụjụ
